MODOUT
Bulk Data Entry Options for displacement and energy results, based on eigenvectors from PFMODE modal participation.
MODOUT ID
  OTYPE OPTIONS GROUP
MODOUT 3
  DISP ALL
  ESE ALL PROP
  EKE ALL COMP
ID Identification number. This can be referenced on the PFMODE I/O Options Entry.
No default (Integer > 0)
OTYPE Output type.
DISP
Continuation line to request Displacement output based on eigenvectors from PFMODE.
ESE
Continuation line to request Element Strain Energy output based on eigenvectors from PFMODE.
EKE
Continuation line to request Element Kinetic Energy output based on eigenvectors from PFMODE
No default
OPTIONS
YES, ALL, blank
Element strain energy and strain energy density are output for all elements.
NO, NONE
Element strain energy and strain energy density are not output.
SID
If a set ID is given, element strain energy and strain energy density are output only for elements listed in that set.
GROUP Corresponding results.
PROP
Output based on Property ID. This output is available in addition to the corresponding elemental output.
COMP
Output based on HM Component. This output is available in addition to the corresponding elemental output.
SET
Output based on Set ID. This output is available in addition to the corresponding elemental output.
  1. MODOUT Identification numbers are not unique. You can define multiple MODOUT entries with the same ID.
  2. Duplicated OTYPE continuation lines are not allowed. Only one of each OTYPE (DISP) is allowed in a particular MODOUT Bulk Data Entry.
