ISTSADD
Bulk Data Entry Defines initial stress condition for nonlinear quasi-static analysis as a union of INISTRS entries.
ISTSADD ID IS1 IS2 IS3 IS4 IS5 IS6 IS7
  IS8 IS9 etc.
ISTSADD 9 101 102 103
ID Unique identification number.
No default (Integer > 0)
IS(i) Identification number of INISTRS entries. The IS(i) values must be unique.
  1. ISTSADD and INISTRS should not have the same ID.
  2. The ISTSADD Bulk Data Entry is selected by the Subcase Information command INISTRS.
