SEQSET
Bulk Data Entry Defines the generalized degrees-of-freedom of the superelement for use in One-Step Superelement Analysis.
SEQSET | SEID | G1 | C1 | G2 | C2 | G3 | C3 |
SEQSET | 11 | 23 | 123456 | 8 | 1 | 5 | 3 |
SEID | Superelement
identification number. No default (Integer ≥ 0) |
Gi | Grid or Scalar Point
identification numbers (should be an external point). Default = Blank (Integer > 0) |
Ci | Component
numbers. Integer zero or blank for scalar points, or up to six unique digits (0 < digit ≤ 6) may be placed in the field with no embedded blanks for grid points. The components refer to the coordinate system referenced by the grid points. |
- Degrees-of-freedom on SEQSET entry should not be used on any other superelement.
