PRSPENE
Bulk Data Entry Defines a pressure penetration load which can simulate fluid penetrating through the surfaces on a contact interface.
PRSPENE SID CTID SPDIR MPDIR TRMP
+ P1 PCRT1 SG1/SSET1 FSSET1 MG1/MSET1 FMSET1
+ P2 PCRT2 SG2/SSET2 FSSET2 MG2/MSET2 FMSET2
+ etc.
SID Load set identification number.
No default (Integer > 0)
CTID Contact interface identification number on which the pressure penetration load is to be applied.
SPDIR Orientation of the pressure applied on the secondary surface. Applies only to secondaries that consist of shell elements. Secondaries defined on solid elements are always subjected to pressure pointing inwards (which is against the default vector normal to the element face) irrespective of this flag.
REVNORM (Default)
Contact force is oriented opposite to the default vector normal to the secondary surface.
NORM
Contact force is oriented along the vector normal to the secondary surface.
(Character)
MPDIR Orientation of the pressure applied on the main surface. Applies only to mains that consist of shell elements. Mains defined on solid elements are always subjected to pressure pointing inwards (which is against the default vector normal to the element face) irrespective of this flag.
REVNORM (Default)
Contact force is oriented opposite to the default vector normal to the main surface.
NORM
Contact force is oriented along the vector normal to the main surface.
(Character)
TRMP Time period over which the pressures at newly penetrated areas are to be ramped up to the current level of a regular load. 6
Default = 0.001 (0.0 < Real ≤ 1.0)
Pi Pressure pool magnitude.
No default (Real > 0.0)
PCRTi Critical value of the normal contact pressure below which the fluid can penetrate through.
Default = 0.0 (Real > 0.0)
SGi/SSETi
SGi
Identification number of a grid initially exposed to fluid on the secondary surface where the fluid pressure starts to penetrate. 2
SSETi
An identification for a SET of grids initially exposed to fluid on the secondary surface where the fluid pressure starts to penetrate. In this case, the FMSET field must be specified.
FSSETi Flag which indicates that the SGi/SSETi field is identified as a SET or a grid point.
GSET
SGi/SSETi field is identified as a SET of grid points.
Blank (Default)
SGi/SSETi field is identified as a grid point.
(Characters)
MGi/MSETi
MGi
Identification number of a grid initially exposed to fluid on the main surface where the fluid pressure starts to penetrate. 2
MSETi
An identification for a SET of grids initially exposed to fluid on the main surface where the fluid pressure starts to penetrate. In this case, the FMSET field must be specified.
Blank (Default)
No grids on the main is specified as initial point.
(Blank or Integer > 0)
FMSETi Flag which indicates that the MGi/MSETi field is identified as a SET or a grid point.
GSET
MGi/MSETi field is identified as a SET of grid points.
Blank (Default)
MGi/MSETi field is identified as a grid point.
(Characters)
  1. The pressure penetration load can simulate the behaviors of fluid pressure spreading on the surfaces of a contact interface.
  2. A secondary grid-based spreading strategy is adopted, which allows the fluid pressure penetrating adjacent areas on the secondary surface, starting from the initial grids specified in the SGi/SSETi field, until it gets blocked at areas where the normal contact pressure is beyond the critical value, PCRTi. On the main side, the pressure load is then applied accordingly by projecting the geometric pattern of obstacles and penetrated grids from the secondary surface. There may be main areas with no projection from the secondary detected, but are supposed to be pressurized, in such cases, the optional field MGi/MSSETi can be used that specifies the initial pressure pool properties on the main as an additional input.
  3. Groups of connected grid points which are divided by the obstacles can be identified as different pressure pools. Each continuation line defines the properties (initial grids, pressure magnitude and critical contact pressure) of an initial pressure pool. Multiple initial grids with different pool properties are allowed through multiple continuation lines. Pools would merge or split during the fluid penetration process. When pools with different properties merge, the largest fluid magnitude and the largest critical contact pressure value are assigned to the merged pool.
  4. The pressure penetration load is updated at the beginning of each nonlinear load increment and remains constant during all iterations in the increment.
  5. The main and the secondary sides on the contact interface must be defined as surfaces or elements SETs. Self-contact is not supported for the pressure penetration load. Contact interface of type FREEZE is not supported.
  6. The external force applied could change frequently at grid points subjected to pressure penetration load. The field, TRMP controls the time period, relative to the entire subcase time, over which the pressures at contact status change are to be ramped up or down. shows an example load ramping curves of grid points which are subjected to PRSPENE referenced by a Subcase Information Entry LOAD, in comparison with a ramping curve of a regular LOAD. In this example, the penetration status of the grid point changed three times over two consecutive nonlinear static subcases. Also, PRSPENE can be referenced by DLOAD/TLOADi, and field TRMP is effective in a similar way.
    Figure 1. Example load ramping curves for a grid with pressure penetration load
  7. PRSPENE can be referenced by TLOADx entries, similar to pressure load.
  8. PRSPENE is supported for the following analysis types:
    • Linear static analysis (only for TYPE=SLIDE)
    • Nonlinear static analysis (small and large displacement)
    • Nonlinear transient analysis (small and large displacement)
  9. Pressure penetration is currently not supported for the following cases:
    • 2D (axisymmetric, plane stress and plane strain) analyses
    • Explicit Dynamic Analysis
    • Self-contact
    • Contact interface of TYPE=FREEZE
