QVOLLIB
Bulk Data Entry Defines the external function called to calculate time and temperature-dependent rate of volumetric heat addition in a conduction element.
QVOLLIB SID GROUP FUNCT
SID Load set identification number.
No default (Integer > 0)
GROUP Defines the shared/dynamic library to be used.
Refers to an existing LOADLIB entry in the input deck.
No default (Character)
FUNCT Defines the external function to be used.
  1. The load set identification number (SID) must match the corresponding identification number on the QVOL entry.
