FLFACT
Bulk Data Entry Used to specify the aerodynamic factors in aerodynamic flutter analysis.
The aerodynamic factors are:
  • Density ratios
  • Mach numbers
  • Reduced frequencies
  • Velocities
Format 1
FLFACT ID F1 F2 F3 F4 F5 F6 F7
F8 F9 etc. etc. etc.
Format 2
FLFACT ID F1 THRU FNF NF FMID
Example 1
FLFACT 1002 0.1 0.56 1.01 4.0
Example 2
FLFACT 1003 0.120 THRU 0.550 10 0.26
ID Unique identification number.
No default (Integer > 0)
Fi Aerodynamic factor value.
Format 1
List of aerodynamic factors.
Format 2
Only F1 needs to be specified and it is the value of the first aerodynamic factor.
No default (Real)
FNF Final aerodynamic factor value.
Required when Format 2 is used.
No default (Real)
NF Number of aerodynamic factors.
FMID Intermediate aerodynamic factor value. 5 6
No default (Real)
  1. The FLFACT Bulk Data Entry must be referenced by a FLUTTER Bulk Data Entry. Unreferenced FLFACT entries will be ignored during the analysis.
  2. Multiple FLFACT entries can point to the same FLUTTER Bulk Data Entry.
  3. Each FLFACT entry must contain data of only one type of aerodynamic factor.
  4. The order of the factors in the FLFACT entries determines the order in which they will be used withing the looping of aerodynamic flutter analysis.
  5. When Format 2 is used, FMID must lie between F1 and FNF.(1)
    F 1 ( F N F − F M I D ) ( N F − i ) + F N F ( F M I D − F 1 ) ( i − 1 ) ( F N F − F M I D ) ( N F − i ) + ( F M I D − F 1 ) ( i − 1 ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaaSaaaeaaca WGgbGaaGymamaabmaabaGaamOraiaad6eacaWGgbGaeyOeI0IaamOr aiaad2eacaWGjbGaamiraiaacMcacaGGOaGaamOtaiaadAeacqGHsi slcaWGPbGaaiykaiabgUcaRiaadAeacaWGobGaamOraiaacIcacaWG gbGaamytaiaadMeacaWGebGaeyOeI0IaamOraiaaigdaaiaawIcaca GLPaaacaGGOaGaamyAaiabgkHiTiaaigdacaGGPaaabaGaaiikaiaa dAeacaWGobGaamOraiabgkHiTiaadAeacaWGnbGaamysaiaadseaca GGPaGaaiikaiaad6eacaWGgbGaeyOeI0IaamyAaiaacMcacqGHRaWk caGGOaGaamOraiaad2eacaWGjbGaamiraiabgkHiTiaadAeacaaIXa GaaiykaiaacIcacaWGPbGaeyOeI0IaaGymaiaacMcaaaaaaa@6B31@
    Where, i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@ = 1, 2, …, NF.
  6. When Format 2 is used, the value of FMID determines the distribution of the factors.
    • If FMID = ( F1+FNF ) 2 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaaSaaaeaada qadaqaaiaadAeacaaIXaGaey4kaSIaamOraiaad6eacaWGgbaacaGL OaGaayzkaaaabaGaaGOmaaaaaaa@3D1C@ , the factors are equally distributed between F1 and FNF.
    • Otherwise, the factors are unequally distributed and will be concentrated around FMID.
  7. If METHOD = PK in the FLUTTER definition and if a FLFACT is used to specify velocities, then the velocities must be non-zero.
  8. If METHOD = PK or PKNL in the FLUTTER definition:
    • Entering negative values produces eigenvector results at a velocity equal to the positive value of the input.
    • Entering positive values produces eigenvalue results without eigenvectors.
