MBREQ
Bulk Data Entry Defines a multibody as a combination of request sets defined via MBREQE and MBREQM.
MBREQ SID R1 R2 R3 R4 R5 R6 R7
  R8 R9 etc
MBREQ 3 31 34 35
SID Request set identification number.
(Integer > 0)
Ri Request set identification numbers defined via entry typed enumerated above. The Ri must be unique.
(Integer > 0)
  1. Request sets must be selected in the Subcase Information section (REQUEST) if they are to be applied.
