CSUPEXT
Bulk Data Entry Defines the Exterior grid points for One-Step Superelement Analysis.
CSUPEXT SEID G1 G2 G3 G4 G5 G6 G7
Alternate Format
CSUPEXT SEID G1 THRU G2
CSUPEXT 6 55 933 23 231 355
SEID Superelement identification number.
No default (Integer ≥ 0)
Gi Grid or Scalar Point identification numbers.
Default = Blank (Integer > 0, or THRU)
  1. If THRU option is used, then G1 should always be less than G2.
