SPOINT
Bulk Data Entry Defines scalar points.
SPOINT ID1 ID2 ID3 ID4 ID5 ID6 ID7 ID8
Alternate Format
SPOINT ID1 "THRU" ID2
SPOINT 3 18 1 4 16 2 6 THRU
  8 47 99 THRU 128
ID# Unique scalar point identification number.
No default (0 > Integer)
  1. A scalar point defined by its appearance on the connection entry for a scalar element (see the CELAS, CMASS, and CDAMP entries) does not need to appear on an SPOINT entry.
  2. This entry is used primarily to define scalar points appearing in single-point or multipoint constraint equations to which no scalar elements are connected.
  3. If the alternate format is used, all scalar points ID1 through ID2 are defined. ID1 must be less than ID2.
  4. Alternate format can be combined with regular format, and it can span across continuation lines.
  5. This card is represented as a node in HyperMesh.
