Bulk Data Entry Defines degrees-of-freedom to be excluded from AUTOSPC.
| (1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
| SPCOFF1 |
C |
G1 |
G2 |
G3 |
G4 |
G5 |
G6 |
G7 |
G8 |
G9 |
etc. |
Alternate Format
| (1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
| SPCOFF1 |
C |
G1 |
THRU |
G2 |
| (1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
| SPCOFF1 |
3 |
22 |
12 |
52 |
7 |
Alternate Example
| (1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
| SPCOFF1 |
4 |
9 |
THRU |
52 |
Definition
| Field |
Contents |
SI Unit Example |
| C |
Component numbers. (Integer zero or blank for scalar
points, or up to six unique digits (0 < digit ≤ 6) may be
placed in the field with no embedded blanks for grid
points).
| Gi |
Grid or scalar point identification numbers. (Integer > 0
or “THRU”)
- Degrees-of-freedom on this entry
will be excluded from AUTOSPC.
- If both SPC
and SPCOFF1 are defined for the same degree-of-freedom,
then SPC takes priority.
- For the THRU option, all grid
points numerically in between G1 and
G2 are not required to exist.
