AECOMPL
Bulk Data Entry Defines a component for use in monitoring point definition or external splines.
AECOMPL NAME LABEL1 LABEL2 LABEL3 LABEL4 LABEL5 LABEL6 LABEL7
LABEL8 etc.
AECOMPL WING1 CSURF FLAP
NAME Character string to identify the component.
(Character; up to 8 characters)
LABELi Names of components defined by other AECOMP or AECOMPL entries.
  1. The NAME field should be unique among all AECOMP and AECOMPL entries.
  2. The AECOMPL entry can be used to combine AECOMP entries into new components. When combining components, the structural and aerodynamic mesh-based components should always be separate.
