THIST
Bulk Data Entry Defines the time history output request for Nonlinear Explicit Analysis.
| THIST | SID | DTTH | FILE | ||||||
| LABEL | TH_group_name | ||||||||
| ENTRY | ID | CID | VAR1 | VAR2 | VAR3 | VAR4 | VAR5 | ||
| VAR6 | VAR7 | etc. |
| ENTRY | ID | VAR1 | VAR2 | VAR3 | VAR4 | VAR5 | VAR6 | ||
| VAR7 | VAR8 | etc. |
| THIST | 10 | 100 | |||||||
| LABEL | groupA | ||||||||
| GRID | 101 | 0 | DEF | REACX | REACY | REACZ | |||
| SOLID | 102 | DEF | |||||||
| CONTACT | 501 | FNX | FTX | FNY | |||||
| SID | Identification number of a
THIST entry. This does not need to be
unique. No default (Integer > 0) |
| DTTH | Frequency of the time
history output.
Default = 100 (Integer > 0 or Real > 0.0) |
| FILE | Suffix for the file name.
A maximum of 4 characters are allowed. This is beneficial with multiple THIST definitions, when specific results are desired in each file. By default, only one _TH.h5 file is generated. For example,
Default = blank (Character) |
| LABEL | Label for the time history
file. No default (Character) |
| ENTRY | Flag indicating that a
list of identifiers is following. Any number of entries can be
specified under the same THIST entry.
| ID | Identifier for each
ENTRY. 4 (Integer > 0) |
| CID | Output coordinate
system. This is only applicable for ENTRY = GRID and SHELL. Default = 0 (Global coordinate system) (Integer) |
| VARi | Output data label. 4 No default (Character) |
- The THIST Bulk Data Entry must be referenced using the THIST Subcase Information Entry. It is only applicable for Explicit Dynamic Analysis (ANALYSIS = NLEXPL).
- The time history output is available in a _TH.h5 file HDF5 format file.
- If a THIST entry
has been referenced in the subcase, the global energy results are always
output by default. Even if FILE is defined, the global
energies are written only to the _TH.h5 file and not to
the other _TH<FILE>.h5 files. The global energies
are listed as follows:
- Output Data Label
- Description and Remarks
- IE
- Global internal energy.
- KE
- Global kinetic energy.
- CE_ELAST
- Elastic contact energy.
- CE_FRIC
- Frictional contact energy.
- HE
- Global hourglass energy.
- EFW
- Global external forces work.
- TE
- Energy sum = IE + KE.
- The following table summarizes the
ENTRY, ID and
VARi values for different output requests.Note: If VARi = ‘character prior to the parenthesis’, then all the results inside the parenthesis are output. For example, with ENTRY = SHELL.
- VARi = STRESS outputs time histories of F1, F2, F12, Q1, Q2, M1, M2 and M12.
- VARi = F1 only outputs time histories of F1.
Entry ID Output Data Label (VARi) Description and Remarks GRID Grid SET ID DEF (DX, DY, DZ, VX, VY, VZ). All six components of displacement are output D (DX, DY, DZ) Translational displacement components V (VX, VY, VZ) Translational velocity components A (AX, AY, AY) Translational acceleration components DR (DRX, DRY, DRZ) Rotational displacement components VR (VRX, VRY, VRZ) Angular velocity components ARX (ARX, ARY, ARZ) Angular acceleration components REACX, REACY, REACZ Reaction force components REACXX, REACYY, REACZZ Reaction moment components SHELL Element SET ID DEF (F1, F2, F12, M1, M2, M12) Components 1, 2 and 12 of stresses and moments per unit length per thickness square are output STRESS (F1, F2, F12, Q1, Q2, M1, M2, M12) F1, F2, F12: Stress in direction 1, 2, 12 Q1, Q2: Mean stress in direction 13, 23
M1, M2, M12: Moments per unit length per thickness square in direction 1, 2, 12
STRAIN (E1, E2, E12, SH1, SH2, K1, K2, K12) E1, E2, E12: Stress in direction 1, 2, 12 SH1, SH2: Shear strain in direction 1, 2
K1, K2, K12: Curvature in direction 1, 2, 12
SOLID Element SET ID DEF (SX, SY, SZ, SXY, SYZ, SXZ) All stress tensor components are output STRESS (SX , SY, SZ, SXY, SYZ, SXZ). SX , SY, SZ, SXY, SYZ, SXZ: Stress tensor components EPSXX, EPSYY, EPSZZ, EPSXY, EPSYZ, EPSXZ Strain tensor components. CONTACT Contact ID DEF (FNX, FNY, FNZ, FTX, FTY, FTZ) All contact force components are output FN (FNX, FNY, FNZ) Normal contact force components FT (FTX, FTY, FTZ) Tangential contact force components
