Bulk Data Entry Defines void
material for geometric nonlinear analysis.
| (1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
| MATX0 |
MID |
| (1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
| MAT1 |
102 |
10.0 |
0.495 |
6.0E-10 |
| MATX0 |
102 |
| Field |
Contents |
SI Unit Example |
| MID |
Material ID of the associated
MAT1. 1 No default
(Integer > 0)
- The
material identification number must be that of an existing MAT1 Bulk Data Entry. Only one MATX0
material extension can be associated with a particular MAT1.
- MATX0 is only applied
in geometric nonlinear analysis subcases which are
defined by ANALYSIS=EXPDYN Subcase Information
Entry. For all other subcases, it is treated as an
elastic material defined by the associated
MAT1.
- This
card is represented as an extension to a
MAT1 material in HyperMesh.
