MBDEACT
Bulk Data Entry Defines the entity/set that needs to be deactivated in the multibody system for the subsequent simulation.
MBDEACT ID ETYPE ID1 ID2 ID3 etc
or
MBDEACT ID ETYPE IDST THRU IDEND
MBDEACT ID MOTION 92 94 199
ID Unique identification number.
(Integer > 0)
ETYPE Entity type that needs to be deactivated.
CMBEAM
CMBUSH
CMSPDP2
JOINT
MLOAD
MOTION
ID1, ID2, ... Entity/Set ID that needs to be deactivated.
(Integer > 0)
IDST Entity/Set ID range start.
(Integer > 0)
THRU Keyword to indicate entity/set ID range is specified.
IDEND Entity/Set ID range end.
(Integer > IDST)
  1. This card is represented as a load collector in HyperMesh.
