TICA
Bulk Data Entry Defines values for the initial velocity of a set of grids along and about an axis for explicit analysis.
| TICA | SID | GSID | VT | VR | |||||
| GA/XA | YA | ZA | GB/XB | YB | ZB |
| TICA | 100 | 10 | 3.0 | 4.0 | |||||
| 123 | 0.0 | 0.0 | 1.0 |
| SID | Set identification
number. (Integer > 0) |
| GSID | Grid point set
identification number. Default = all grids in the model (blank or Integer > 0) |
| VT | Initial velocity along the
axis. (Real) |
| VR | Initial velocity about the
axis. (Real) |
| GA, XA, YA, ZA | Axis origin. These fields
define the origin of the axis. The point may be defined by entering
a grid ID in the GA field or by entering X, Y,
and Z coordinates in the XA,
YA, and ZA fields; these
coordinates will be in the basic coordinate system. Default is the origin of the basic system (Real in all three fields or Integer in first field) |
| GB/XB, YB, ZB | Direction of vector for
axis definition. These fields define a point. The vector goes from
the anchor point to this point. The point may be defined by entering
a grid ID in the GB field or by entering X, Y,
and Z coordinates in the XB,
YB, and ZB fields; these
coordinates will be in the basic coordinate system. No default (Real in all three fields or Integer in first field) |
- Explicit analysis initial condition sets must be selected with the Subcase Information command IC=SID. It can only be selected in explicit subcases which are defined by an ANALYSIS=EXPDYN Subcase Information Entry.
- TICA is primarily used for simulating the uniform rotation of a structure about an axis by defining VR and an axis. A helical (or spiral) shaped motion can also be achieved by defining VR, VT and an axis.
- This card is represented as a load collector in HyperMesh.
