DVCREL2
Bulk Data Entry Relates design variables to an analysis model element property using a relationship defined by a DEQATN card. The equation inputs come from the referenced DESVAR values and constants defined on a DTABLE card.
DVCREL2 ID TYPE EID EPNAME/
FID
    EQID
  DESVAR DVID1 DVID2 DVID3 DVID4 DVID5 DVID6 DVID7
    DVID8 DVID9 etc.
  DTABLE LABL1 LABL2 LABL3 LABL4 LABL5 LABL6 LABL7
    LABL8 etc.
ID Relationship identification number. ID must be unique with respect to other DVCREL2 cards.
No default (Integer > 0)
TYPE Element type to be related (DVCREL - Types)
No default (Character)
EID Element identification number.
EPNAME/FID Element property name, such as "K" or "ZOFFS" (as in the documentation of the element Bulk Data Entries), or field number on an element Bulk Data Entry.
No default (Character or Integer > 0)
EQID Equation ID of DEQATN data.
DESVAR Indicates DESVAR ID numbers follow.
DVID# DESVAR ID.
DTABLE Indicates DTABLE labels follow.
LABL# Constant label. Must match with a constant label of a DTABLE entry.
  1. This card is represented as an optimization design variable property relationship in HyperMesh.
