MONPNT2
Bulk Data Entry Define an integrated load monitor point for specific elements and to output results for these elements.
MONPNT2 NAME LABEL
TABLE TYPE NDDLitem EID
MONPNT2 PART12 Stringer load
STRESS CBAR SX2A 101
Definition
NAME Unique character string identifier for the monitor point.
No default (Character)
LABEL A character string that identifies and labels the monitor point.
Up to 56 characters are supported.
Default = blank (Character)
TABLE Type of the output to be monitored. 2
STRESS
STRAIN
FORCE
TYPE Type of the element to be monitored.
NDDLitem Item code for the element type to be monitored.
List of supported elements and their codes can be found in the NDDL item code table.
EID ID of the element to be monitored.
No default (Integer > 0)
  1. The MONPNT2 entry is supported only for linear static and static aeroelastic analysis.
  2. If invalid entities are specified in TABLE, TYPE, NDDLitems or EID fields, an error message will be issued.
  3. The results requested by the MONPNT2 entry will be printed to the .monpnt file.
