PCOMPX
Bulk Data Entry Defines additional composite laminate properties for geometric nonlinear analysis.
| PCOMPX | PID | ISHELL | ISH3N | ISMSTR | HM | HF | HR | ||
| DM | DN | ITHICK | IPLAS |
| PCOMP | 73 | ||||||||
| 120 | 0.2 | 0.0 | YES | 120 | 0.6 | 45.0 | YES | ||
| PCOMPX | 73 | 24 |
| PID | Property ID of the associated PSHELL. 1 No default (Integer > 0) |
| ISHELL | CQUAD4 element formulation flag.
Default as defined by XSHLPRM (Integer) |
| ISH3N | CTRIA3 element formulation flag.
| ISMSTR | Shell small strain formulation
flag.
| HM | Shell membrane hourglass coefficient
(ISHELL = 1, 2, 3, and
4 only). Default = 0.01 (Real, 0.0 ≤ HM ≤ 0.05) Except ISHELL = 3: Default = 0.1 (Real) |
| HF | Shell out of plane hourglass
coefficient (ISHELL = 1, 2, 3, and
4 only). Default = 0.01 (Real, 0.0 ≤ HF ≤ 0.05) |
| HR | Shell rotation hourglass coefficient
4 only). Default = 0.01 (Real, 0.0 ≤ HR ≤ 0.05) Except ISHELL = 3: Default = 0.1 (Real) |
| DM | Shell membrane damping (with
MATX27, MATX36 only). Default: 7 (Real) |
| DN | Shell numerical damping (ISHELL = 12, 24; ISH3N = 30 only). Default: 8(Real) |
| ITHICK | Shell resultant stresses calculation
flag.
Default as defined by XSHLPRM (CONST or VAR) |
| IPLAS | Shell plane stress plasticity flag
(with MATX27 only).
Default as defined by XSHLPRM (RAD or NEWT) |
- The property identification number must be that of an existing PCOMP, PCOMPG, or PCOMPP Bulk Data Entry. Only one PCOMPX property extension can be associated with a particular PCOMP, PCOMPG, or PCOMPP.
- PCOMPX is only applied in geometric nonlinear analysis subcases which are defined by ANALYSIS = EXPDYN. It is ignored for all other subcases.
- Q4:
Original 4 node OptiStruct shell with hourglass perturbation
stabilization.
QEPH: Formulation with physical hourglass stabilization for general use.
QBAT: Modified BATOZ Q4 24 shell with 4 Gauss integration points and reduced integration for in-plane shear. No hourglass control is needed for this shell.
DKT18: BATOZ DKT18 thin shell with 3 Hammer integration points.
- If the small strain option (ISMSTR) is set to 1 or 3, engineering strain and stress are used; otherwise they are true strain and stress.
- If ITHICK = VAR or IPLAS = NEWT, the small strain option is automatically deactivated.
- Defaults for DM:
Material Element Type ISHELL/ISH3N Default MATX27 except QEPH, QBAT except 12, 24 5% QEPH 24 1.5% QBAT 12 0% MATX36 except QEPH except 24 0% QEPH 24 1.5% - Defaults for DN:
Element Type ISHELL/ISH3N Default Usage QBAT 12 0.1% All stress terms, except transverse shear QEPH 24 1.5% Hourglass stress DKT18 12/30 0.01$ Membrane stress only - This card is represented as extension to a PCOMP, PCOMPG, and PCOMPP property in HyperMesh.
