TEMP
Bulk Data Entry Defines temperature at grid points or a SET of grid points for determination of Thermal Loading and Stress recovery.
| TEMP | SID | G/ GSETID |
T | G | T | G | T | ||
| GSET |
| TEMP | 3 | 94 | 316.2 | 49 | 219.8 |
| SID | LOAD
set identification. (Integer > 0) |
| G/GSETID | This field represents a
grid point identification number, or if the GSET
continuation line is specified, an identification number of a
SET of grid points. (Integer > 0) |
| T | Temperature. (Real) |
| GSET | Flag which indicates that the G/GSETID field is identified as a SET of grid points, at which the temperatures are applied. |
- Temperature sets may be selected for use in a subcase by the TEMPERATURE or TEMPERATURE(BOTH) Subcase Information Entry. For transient heat transfer analysis, the temperature set can be selected by IC Subcase Information Entry to specify initial condition.
- From one to three grid point temperatures may be defined on a single entry. If GSET continuation line is present, then the referenced SET can consist of any number of grid points.
- This card is represented as a temperature load in HyperMesh.
