MARKER
Bulk Data Entry Define a marker by associating a grid and a coordinate system.
MARKER MID1 GID1 CID1 MID2 GID2 CID2
  MID3 GID3 CID3 etc etc etc
MARKER 3 345 123
MIDi Marker identification number.
Each marker has a unique ID. The marker gets its location from the grid corresponding to the GID and the orientation from the coordinate system (CID).
(Integer > 0)
GIDi Grid identification number.
(Integer > 0)
CIDi Coordinate system identification number.
(Integer ≥ 0 or blank)
Default (Blank, defaults to basic coordinate system)
  1. Multiple markers can be located at the same grid with the same or with a different CID.
  2. This card is represented as a sensor in HyperMesh.
