MBACT
Bulk Data Entry Defines the entity/set that needs to be activated in the multibody system for the subsequent simulation.
MBACT ID ETYPE ID1 ID2 ID3 etc
or
MBACT ID ETYPE IDST THRU IDEND
MBACT ID MOTION 92
ID Unique identification number.
(Integer > 0)
ETYPE Entity type that needs to be activated.
CMBEAM
CMBUSH
CMSPDP
JOINT
MLOAD
MOTION
ID1, ID2, ... Entity/Set IDs that need to be activated.
(Integer > 0)
IDST Entity/Set ID range start.
(Integer > 0)
THRU Keyword to indicate entity/set ID range is specified.
IDEND Entity/Set ID range end.
(Integer > IDST)
  1. This card is represented as a load collector in HyperMesh.
