MAT1
Bulk Data Entry Defines the material properties for linear, temperature-independent, and isotropic materials.
| MAT1 | MID | E | G | NU | RHO | A | TREF | GE | |
| ST | SC | SS | |||||||
| MODULI | MTIME | ||||||||
| RAYL | ALPHA | BETA |
| MAT1 | 17 | 3.+7 | 0.33 | 4.28 |
| MID | Unique material identification.
No default (Integer > 0 or <String>) |
| E | Young's modulus. Default = blank (Real or blank) |
| G | Shear modulus. Default = blank (Real or blank) |
| NU | Poisson's ratio. If < 0.0, a warning is issued. Default = blank (-1.0 < Real < 0.5 or blank) |
| RHO | Mass density. Used to
automatically compute mass for all structural elements. No default (Real) |
| A | Thermal expansion
coefficient. No default (Real) |
| TREF | Reference temperature for
thermal loading. Default = 0.0 (Real) |
| GE | Structural element damping
coefficient. 10
11 No default (Real) |
| ST, SC, SS | Stress limits in tension,
compression and shear. Used for composite ply failure
calculations. No default (Real) |
| MODULI | Continuation line flag for moduli temporal property. 12 | |
| MTIME | Material temporal
property. This field controls the interpretation of the input
material property for viscoelasticity.
| RAYL | Continuation line flag for material-dependent Rayleigh damping. | |
| ALPHA | Material-dependent
Rayleigh Damping coefficient for the mass matrix. Default = blank (Real ≥ 0.0) |
| BETA | Material-dependent
Rayleigh Damping coefficient for the stiffness matrix. Default = blank (Real ≥ 0.0) |
- The material identification number/string must be unique for all MAT1, MAT2, MAT8 and MAT9 entries.
- String based labels allow for easier visual identification of materials, including when being referenced by other cards. (example, the MID field of properties). For more details, refer to String Label Based Input File in the Bulk Data Input File.
- Either E or G must be specified (that is, non-blank).
- If any one of E,
G, or NU is blank, it is computed to
satisfy the identity,
E = 2(1+NU)G; otherwise, values supplied by you are used.
- If E and NU are both blank, they are both given the value 0.0.
- If G and NU are both blank, they are both given the value 0.0.
- Unlikely data on one or more
MAT1 entries result in a warning message. Unlikely data
is defined as:
- E < 0.0 or
- G < 0.0 or
- NU > 0.5 or
- NU < -1.0 or
- except for cases covered by comments 5 and 6.
- It is strongly recommended that only two of the three values E, G, and NU be input.
- The large field format may also be used.
- To obtain the damping coefficient GE, multiply the critical damping ratio, by 2.0.
- TREF and GE are ignored, if a MAT1 entry is referenced by a PCOMP, PCOMPP, or PCOMPG Bulk Data Entries.
- MODULI continuation line is only applicable when used together with the MATVE entry. Refer to MATVE which provides additional information on how this material input is interpreted.
- This card is represented as a material in
HyperMesh.
Element Type E NU G CROD, CBAR, CBEAM, and CWELD Axial and Bending N/A Transverse Shear and Torsion CSHEAR N/A N/A Shear CQUAD and CTRIA Membrane and Bending Membrane and Bending Transverse Shear CHEX, CTETRA, CPENTA, CPRYRA and CSEAM Deformation N/A
