EDRAWB
Bulk Data Entry Defines location and restraining force per unit length for a draw bead in a one-step stamping simulation.
EDRAWB EID S1 T2 S2 T2 DFORCE DSID
EDRAWB 13 -1.0 1.0 1.0 -1.0 100.0 2
EID Element identification number.
No default (Integer > 0)
S1, T1 Parametric entry points for the line.
No default (Real; | S1, T1 | ≤ 1.0)
S2, T2 Parametric exit points for the line.
No default (Real; | S2, T2 | ≤ 1.0)
DFORCE Draw bead restraining force per unit length.
No default (Real)
DSID Draw bead set identifier for retrieving the input file back to HyperForm. Not used by the solver.
  1. This entry is only valid with an @ HyperForm statement in the first line of the input file.
