MBVAR
Bulk Data Entry Defines a multibody solver variable which can be referred to by multiple expressions.
MBVAR VID EXPR
MBVAR 3 IMPACT(Dz(30301020,30302040),VZ(30301020,30302040),0.0,4
  00,1.0,0.5,0.000)
VID Variable identification number.
(Integer > 0)
EXPR Character string expression. The expression can spawn multiple lines. The continuation lines will start from the second column. Refer to Function Expressions.
  1. The variable ID can be referenced by VARVAL(VID) in multiple expressions in the model.
