CMBUSHT
Bulk Data Entry Defines a bushing element without reference to a property entry.
CMBUSHT EID   G1 G2 X1, G3 Y1 Z1
    "K" K1TID K2TID K3TID K4TID K5TID K6TID
    "B" B1TID B2TID B3TID B4TID B5TID B6TID
    "P" P1 P2 P3 P4 P5 P6
CMBUSHT 4   1 2 1.0 0.0 0.0
    K 100 100 100 1 1 1
    B 1 1 1 1 1 1
    P 0 0 0 0 0 0
EID Unique element identification number.
(Integer > 0)
G1 Grid point identification number.
(Integer > 0)
G2 Grid point identification number.
(Integer > 0)
G3 Grid point identification number to optionally supply X1, Y1, and Z1 in conjunction with G1.
(Integer > 0)
X1, Y1, Z1 Orientation vector of the bushing.
(Real)
K Stiffness specifier.
K1TID, K2TID, K3TID Translational stiffness TABLEDi ID.
Default = 0 (Integer ≥ 0 or blank)
K4TID, K5TID, K6TID Rotational stiffness TABLEDi ID.
B Damping specifier.
B1TID, B2TID, B3TID Translational damping TABLEDi ID.
B4TID, B5TID, B6TID Rotational damping TABLEDi ID.
P Preload specifier.
P1, P2, P3 Translational preload.
P4, P5, P6 Rotational preload.
  1. This card is represented as a spring element in HyperMesh.
