BLKHDF
Bulk Data Entry Defines the blank holder force in a one-step stamping simulation.
BLKHDF BHID MU FORCE TOGGLE
BLKHDF 6 0.3 3.0 0.0
BHID Blank holder identification number.
No default (Integer > 0)
MU Coefficient of friction.
No default (Real > 0.0)
FORCE Blank holder force.
No default (Real)
TOGGLE Flag assigned based on option (Pressure or Tonnage).
0.0
Uniform pressure is applied on blank holder.
1.0
Net force is applied on blank holder.
  1. This entry is only valid with an @ HyperForm statement in the first line of the input file.
