EL2PROP
Bulk Data Entry Used to assign property ID to elements in DMIG.
EL2PROP ID
  ELSETID PTYPE PROPID ELSETID PTYPE PROPID
  etc
Alternate Format
EL2PROP ID ALTER
  PROPID ELSETID ELSETID ELSETID ELSETID ELSETID ELSETID ELSETID
    ELSETID ELSETID etc etc
EL2PROP 7
  8 PSHELL 3
Alternate Format Example
EL2PROP 7 ALTER
  3 8 2
ID Identification number of EL2PROP.
No default (Integer > 0)
ALTER ALTER flag indicating the alternate format is being used.
ELSETID Element set identification number.
PTYPE (Optional) Property type.
PSHELL
PSOLID
PROPID Property identification number.
  1. This EL2PROP Bulk Data Entry can be used to assign Property ID's' to Element sets.
  2. The ID field is only used by HyperMesh. When ECHO entry is present in the model, all EL2PROP entries will be combined into one EL2PROP entry with an internally generated ID. The ID of the EL2PROP entries are not used in OptiStruct.
