MEFFSET
Bulk Data Entry This entry is used to group element sets for which MEFFMASS output is desired in HyperMesh set based format.
MEFFSET ID
+ SETID1 SETID2 SETID3 SETID4 etc.
+ etc. SETIDi etc.
MEFFSET ID
+ 101 102 103 104 105
ID Unique identification number.
This ID must match the SET in MEFFMASS definition.
No default (Integer > 0)
SETIDi Element set ID.
  1. MEFFSET is only applicable with the MEFFMASS entry when output is desired in the form of element sets.
  2. The output is printed to the .out file and also to an .effmass file ASCII format file.
