PPLANE
Bulk Data Entry Defines the properties of plane strain elements (CTPSTN and CQPSTN).
| PPLANE | PID | MID | T |
| PPLANE | 2 | 203 | 0.2 |
Definition
| PID | Unique plane element
property identification number. No default (Integer > 0) |
| MID | Identification number
of MAT1, MAT3 or
MATHE entry. No default (Integer > 0) |
| T | Thickness. Default = 1.0 (Real ≥ 0.0 or blank) |
- All plane strain element property entries must have unique ID numbers.
- Plane strain elements defined via
PPLANE are supported in linear static analysis and
nonlinear (small and large displacement) static analysis. They are currently
not supported for large displacement inertia relief analysis.
Plane strain elements can also be defined via PSHELL (MID2=-1), but this method is only supported for linear static analysis.
