MLOAD
Bulk Data Entry Defines a multibody as a linear combination of load sets defined via GRAV, MBFRC, MBFRCC, MBFRCE, MBMNT, MBMNTC, MBMNTE, MBSFRC, MBSFRCC, MBSFRCE, MBSMNT, MBSMNTC, and MBSMNTE.
MLOAD SID L1 L2 L3 L4 L5 L6 L7
  L8 L9 etc
MLOAD 3 31 34 35
SID Load set identification number. Must be selected in the Subcase Information section (MLOAD = SID), if they are to be applied.
(Integer > 0)
Li Load set identification numbers defined via entry typed enumerated above. The Li must be unique.
(Integer > 0)
  1. An MLOAD entry may not reference a set identification number defined by another MLOAD entry.
  2. This card is represented as a load collector in HyperMesh.
