REPSUB
Subcase Information Entry The REPSUB command can be used in the Subcase Information section, within a subcase definition, to select a report set that is subcase dependent.
REPSUB = integer
Argument Options Description
integer <DRID >
No default
DRID
Set identification of a DREPORT or DREPADD Bulk Data Entry.
  1. The response referenced by the REPSUB selection must be subcase dependent.
