DOPTPRM, MMCHECK
Bulk Data Entry Parameter to ensure a checkerboard-free solution.
Parameter | Values | Description |
MMCHECK | Integer =
0 or 1 Default = 0 |
The use of this parameter, in conjunction with MINDIM, will ensure a checkerboard-free solution, although with the undesired side effect of achieving a solution that involves a large number of semi-dense elements, similar to the result of using CHECKER=1. Therefore, use this parameter only when it is necessary. |
