DRESP1 - Center of Gravity and Moments of Inertia Item Codes
Center of Gravity
- Component
 - ASCIICode
 - x-coordinate
 - X
 - y-coordinate
 - Y
 - z-coordinate
 - Z
Moment of Inertia
- Component
 - ASCII Code
 - lxx
 - XX
 - lyy
 - YY
 - lzz
 - ZZ
 - lxy
 - XY
 - lxz
 - XZ
 - lyz
 - YZ
- By default, the center of gravity and moment of inertia responses are calculated with respect to the basic coordinate system. Refer to PARAM, UCORD to specify a user-defined coordinate system for the calculations.
