RADPRM, XPENTA15
Bulk Data Entry The RADPRM, XPENTA15 parameter controls the support of the second order PENTA element with 15 nodes in explicit dynamic analysis.
Parameter Values Description
XPENTA15 <0, 1>
0 (Default)
Second order CPENTA element is not supported.
1
The converter will convert the second order PENTA element to collapsed second order HEXA element. However, the results can be inaccurate near the second order PENTA depending on the loading.
