Maximum Peak
Max. Peak is available only for studying modal contributions based on nodes as the selected pair.
  1. Select Max. Peak radio button.
  2. Use to navigate in the plot to view the Relative Displacement peaks and time of occurrence.
    The plot highlights the peaks values in relative displacement using horizontal and vertical dashed lines and also shows labels to highlight the same.
  3. Select a value from Select Top Contributors list.
  4. Click Analyze.
    This plots and displays the selected number of top contributing modes in descending order of effect on squeak and rattle.
