Modal Sensitivity Studies
Study the modal contribution and sensitivity.
- Calculate the relative Modal Contribution of the required E-Line to be analyzed.
- Observe the change in results. Specifically, when the modal contribution is
varied buy either including or excluding a certain mode from the result
calculations with the help of Modal Sensitivity study. The relative modal
contribution for a particular E-Line can be calculated
and studied in two ways:
- Study the modal contribution of the complete E-Line.
- Study the modal contribution of a particular node pair of an E-Line.
