Loadcase Selection
Lists all the loadcases present in the results file.
Select E-Line
E-Line interface which you want to optimize.
Optimization Direction
Select the optimization direction.
This selection must be based on the information shown in the Relative
Displacement or Line Graph.
Components
Components that you want to optimize.
Only 2D PSHELL parts must be selected.
Thickness Values
Minimum and Maximum thickness values.
These are picked from the properties of selected components.
Frequency
Identify frequency(s) to optimize the components for.
Frequency table will be empty for static loadcase.
