Static Event
Define a Static (Linear Static) loadcase.
View new features for HyperWorks 2022.2.
Explore the SnRD Pre-Processing user interface.
Use Setup Group to setup evaluation lines and define loadcases.
Import all data required for the Squeak and Rattle Analysis preparation.
Use the Define Interface tool to create, import, and edit geometric lines.
Edit geometric lines.
Use the Create E-Lines tool to create evaluation lines at component interfaces.
Use the Manage E-Line tool to review and manage E-Lines.
Setup loadcases to solve and extract results.
Define a Modal Transient (MTRAN) loadcase.
Description of Static loadcase options.
Define a Temperature (Linear Static) loadcase.
Create Single Point Constraints (SPCs).
Use a Variability Study to examine how squeak and rattle risks are affected by manufacturing variations.
Use the Manage E-Points tool to modify local system collectors and evaluation points.
Evaluate Loadcase and export solver deck.
Explore SnRD Post Processing User Interface.
Use of Altair Ziegler SnR Material Database.
