Analyze
                           Create and edit outputs, create and edit templates, run the solver, view reports,         access the Load Export utility,
                              use the Optimization Wizard, open HyperStudy, utilize many         pre-processing and post-processing capabilities with regards
                              to flexible bodies (or         flexbodies), run MS/EDEM cosimulation in batch mode, and generate H3D from EDEM.
