A parallel axes joint is a four degree-of-freedom primitive constraint. The
        constraint is imposed such that the Z axis of a reference marker on one body (Body 2)
        remains parallel to the Z axis of a reference marker on the other body (Body 1) connected by
        the joint. All three of the translations are free along with one rotation about the Z axis
        of the marker defining the joint orientation. Joint primitives like parallel axes joints may
        not have a physical existence. Parallel axes joints can be used to impose unique constraints
        where using a regular joint would not be possible.
                If the Joints panel is not currently displayed, select the desired joint by
                    clicking on it in the Project Browser or in the modeling window.
                The Joints panel is automatically displayed.
                From the Connectivity tab, click Body
                        1 and pick a body from the modeling window, or double-click Body 1 to open the Model Tree (from which the desired body can be
                    selected).
                    Note: If the selected joint is a pair entity, first distinguish between the
                            Left and Right tabs in the
                        panel, and then edit the properties. When defining a pair joint, use pair
                        entities for Body, Origin, etc.
                Similarly, click Body 2 and
                    select the desired body from the modeling window (or use
                    the Model Tree).
                Click the Point
                    collector (under Origin) and select a point from the modeling window, or double click the
                        Point collector to open the Model Tree (from which the desired point can be selected).
                Specify the properties of the axis that defines the constraint of the joint
If editing a compliant joint, see Edit Compliant Joints or Bushings. To edit user-defined
            properties, see Edit User-Defined Joints.
