An orientation joint is a three degree-of-freedom kinematic pair. The joint
        constrains the three rotational degrees of freedom while all three translations are free.
        Effectively, the orientations of the two bodies connected by the joint remain the
        same.
                If the Joints panel is not currently displayed, select the desired joint by
                    clicking on it in the Project Browser or in the modeling window.
                The Joints panel is automatically displayed.
                From the Connectivity tab, click Body
                        1 and pick a body from the modeling window, or double-click Body 1 to open the Model Tree (from which the desired body can be
                    selected).
                    Note: If the selected joint is a pair entity, first distinguish between the
                            Left and Right tabs in the
                        panel, and then edit the properties. When defining a pair joint, use pair
                        entities for Body, Origin, etc.
                Similarly, click Body 2 and
                    select the desired body from the modeling window (or use
                    the Model Tree).
                Click the Point
                    collector (under Origin) and select a point from the modeling window, or double click the
                        Point collector to open the Model Tree (from which the desired point can be selected).
                An implicit marker is created on Body 1 at that point.
                Repeat the same step for Origin 2.
                An implicit marker is created on Body 2 at that point.
If editing a compliant joint, see Edit Compliant Joints or Bushings. To edit user-defined
            properties, see Edit User-Defined Joints.
