Finite Antenna Array Limitations
A finite antenna array or DGFM is not applicable to all models, but can significantly improve simulation speeds when it can be applied.
- The DGFM is supported for MoM examples containing metallic triangles, wires and connections between them. Skin effect and dielectric / magnetic coatings are supported for metallic surfaces. Coatings and discrete loads are supported for wires.
- VEP and FEM are not allowed in conjunction with the DGFM.
- Only a single FA card is allowed in the model.
