HMIN_blocksimple_write()
Writes a block to HyperMesh for use with interfaces and loadsteps (instead of finite difference blocks).
void HMIN_blocksimple_write(HM_entityidtype id, char * name, int color, double minimum[3], double maximum[3]);
HyperMesh hminlib Function
id
The ID of the block to be written.
name
The name of the block.
color
The color of the block.
minimum[3]
The minimum values of the x, y, and z coordinates in the block.
maximum[3]
The maximum values of the x, y, and z coordinates in the block.
Use this function to transfer any blocks to HyperMesh that are simple enough not to contain any divisions, cells, or walls.
None.
