HMIN_card_write()
Writes a control card to HyperMesh.
void HMIN_card_write(HM_entityidtype id, char *name);
HyperMesh hminlib Function
id
The ID of the control card.
name
The name of the control card.
A template that supports control cards must be used in conjunction with the input translator using the HMIN_card_write() function.
An association between the feinput translator and a HyperMesh template file must exist for control cards to be visible in the card previewer (specified with the feinput function HMIN_setsolver() and the template function *codename()). See the Templates section for a description of the *codename() function.
None.
