HMIN_contactsurf_write_all_nodes()
Writes contact surfaces to HyperMesh.
void HMIN_contactsurf_write_all_nodes(const int totalNodeCount, HM_entityidtype* nodeArray)
HyperMesh hminlib Function
Precursor function to HMIN_contactsurf_write_face_nodes() which helps in collecting all the base elements for the contact surface and helps in accelerating the import of contact surfaces described on nodes.
totalNodeCount
The total number of nodes being imported for base element.
nodeArray
The array of all the face nodes.
None.
