HMIN_controlvol_write()
Writes control volume information to HyperMesh.
void HMIN_controlvol_write(HM_entityidtype id,HM_entityidtype entityid,HM_entitytype type,char *name,int elemidsmax,HM_entityidtype *elemids,int refnodesmax,HM_entityidtype *refnodes_id,double* refnodes_globalxyz, double* refnodes_localxyz)
HyperMesh hminlib Function
id
The ID of the control volume.
entityid
The ID of the entity used to create the control volume.
type
The type of entity used to create the control volume.
name
The name of the control volume.
elemidmax
The number of elements associated with control volume.
elemids
An array containing element ids. The array size will be equal to elemidmax.
refnodesmax
The number of reference nodes associated with control volume.
refnodes_id
An array containing reference nodes ids. The array size will be equal to refnodesmax.
refnodes_globalxyz
An array containing global coordinates (x, y and z) of reference nodes.
refnodes_localxyz
An array containing local coordinates (x, y and z) of reference nodes.
None.
