HMIN_desvarlink_write()
Writes a design variable link to HyperMesh.
void HMIN_desvarlink_write(HM_entityidtype id,char *name,HM_entityidtype desvarid, int desvarlistmax,HM_entityidtype *desvarlist,double c0,double cmult,double *coeff);
HyperMesh hminlib Function
id
The ID of the design variable link.
name
The name of the design variable link.
desvarid
The ID of the dependent design variable.
desvarlistmax
Number of independent design variables.
desvarlist
An array containing the ids of the independent design variables.
c0
Constant term.
cmult
Constant multiplier.
coeff
An array containing the coefficients associated with each of the independent design variables.
None.
