HMIN_ellipsoid_write()
Writes an ellipsoid to HyperMesh.
void HMIN_ellipsoid_write (HM_entityidtype id, char *name, int config, int type, double radiusa, double radiusb, double radiusc, double shape, int systemid, int multibodyid, unsigned char color)
HyperMesh hminlib Function
id
The ID of the ellipsoid.
name
The name of the ellipsoid.
config
The configuration assigned to the ellipsoid.
type
The type assigned to the ellipsoid.
radiusa
The dimension of the ellipsoid.
radiusb
radiusc
shape
The degree of the ellipsoid.
systemid
The ID of the system.
multibodyid
The ID of the multibodies.
color
The color assigned to the group.
None.
