HMIN_form_system()
Creates a valid system from three nodes and writes the information to HyperMesh.
HMIN_form_system(HM_entityidtype systemid, int type, char code, double origin[3], double axis[3], double plane[3],HM_entityidtype syscolid)
HyperMesh hminlib Function
systemid
The ID of the system.
type
The type of system to be written.
  • 0 - For a Cartesian system.
  • 1 - For a cylindrical system.
  • 2 - For a spherical system.
code
The code value is used to determine which point defines two of the three X, Y, or Z vectors of the system. The third vector is then defined by calculating the cross product of the origin to axis and origin to plane vectors. Code is interpreted by HMIN_unpacksystemcode() in the following manner:
  • 1 Axis determines X vector of system.
  • Plane determines Y vector of system.
  • 2 Axis determines X vector of system.
  • 3 Axis determines Y vector of system.
  • Plane determines X vector of system.
  • 4 Axis determines Y vector of system.
  • Plane determines Z vector of system.
  • 5 Axis determines Z vector of system.
  • 6 Axis determines Z vector of system.
origin
The coordinates of the point which specify the system's origin.
axis
The coordinates of the point which specify the system's axis.
plane
The coordinates of the point which specify the plane of the system.
syscolid
The ID of the system collector.
Returns
  • 0 - If function is executed successfully.
  • 1 - If the origin to axis vector is invalid.
  • 2 - If the origin to plane vector is invalid or if the origin to plane and origin to axis vectors cannot be made perpendicular.
  • 3 - If the third vector created from the origin to plane and origin to axis vectors is invalid.
None.
