HMIN_optifunction_write()
Writes design equation definition to HyperMesh.
void HMIN_optifunction_write(HM_entityidtype id, char *name, int number_of_lines,char **string)
HyperMesh hminlib Function
id
The ID of the design equation.
name
The name of the design equation.
number of lines
Number of lines in the equation.
string
Design equation (function) expression as an array of lines.
None.
